By "the gear" can I assume you mean the drive cog on the shaft of the extruder motor? Is it pressed on or does it have set screws?
"Some slipping sounds" Does that mean it's skipping steps like snapping backwards instead of moving the filament forward? Do you have an Auto-Leveling system or are you leveling by hand using a piece of paper?
"20 minutes later it's turning but not moving the filament" So it is grinding away at the filament in one spot? No more extrusion coming out of the nozzle?
GregValiant 741
Ok. Let's start at the beginning.
