19 minutes ago, GregValiant said:With the file loaded and Cura ready to slice use the File | Save Project command and post the 3mf file here.
How has the machine been printing? You have the retraction dialed in and the E-steps calibrated?
Hi @GregValiant thanks for the reply. I do have everything dialed in yes. I did change the small length of bowden tube and the thermal barrel to higher end parts the other day as i was having major issues and turns out the bowden tube had broken inside my old thermal barrel. so once changed i re-calibrated everything. It prints ok apart from that go awful..... "snot" if u like lol. I also have a dual geared extruder too.
Anyway heres the file u asked for.
GregValiant 741
