Sorry, I meant profile or definition.
GregValiant 1,488
A settings profile? That is so model dependent that having more than a couple is useless as you are constantly tweaking them anyways to get it just right for the model.
What kind of things are you looking to print? If it's large flat stuff they need to be printed one way. Tall skinny things need to be printed another way. If you are printing with PLA it's one group of settings. Moving to PETG it's another.
I have three profiles. PLA, PETG, TPU. I installed separate Ender 3 Pro's for each material because I wanted different StartUp Gcodes dependent on the material. I use the Settings Visibility option and set it to "ALL". Once I've picked the printer and material it's: Slice, look at the preview, make changes, slice, look at the preview, make changes. Keep doing it until it looks good.
I suggest you start with models that don't need a lot of supports and are fairly regular. They are the easiest to dial in. Starting out with a complicated figurine / mini or a busy "building diorama" is tough and it's easy to get frustrated. So keep it simple, keep your speeds under about 50 to start, and make a few good prints. Then as you get to know the printer and what it likes and doesn't like you can start getting more aggressive with your settings.
On 6/6/2022 at 1:23 PM, EdwinKort said:Since a couple of weeks I own (thanks to Holiday money) a 3d printer. It's a Creality Sermoon v1 Pro. So far I used the sliver from Creality, but on some other forum they told me to get this one, as it would have support for more printers and generally would work better. So I downloaded it, but couldn't find a driver or settings for my printer. I can use the generic and change settings if that is a good way to do so.
Ps. This would also be my 'introduction' 😉
I took Sermoon D1 and changed see pictures and change G-code to the one attached save then you can change the name from Sermoon D1 to V1 in the menu on the right three dashes. It works well.
Hope it was of some help
Strat G Code
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
G28 ;Home
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y145.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y145.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
G1 E-1.0000 F1800 ;Retract a bit
G1 E0.0000 F1800
End G Code
G91 ;Relative positionning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positionning
G1 X0 Y0 ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
Extruder Start G Code
G92 E0 ;reset extruder distance
M104 S$
Extruder End G Code
G1 F800 E-5 ;short retract
G90
1
Thanks. Going to look at this tomorrow 🙂
Finally had some time to do this. Was a bit hesitant to do, but am glad I finally did.
Nice 🤙
- 10 months later...
Hi! does anybody knows how to turn off the Extruder fan? Creality Sermoon v1
GregValiant 1,488
That is typically controlled by settings in the firmware. In Marlin firmware there isn't any way to over-ride that.
GregValiant 1,488
The Sermoon D1 definition is included with Cura 5.0. You should be able to install the printer in Cura.
Once the printer is installed there should be a couple of profiles available (Draft, Standard, etc.). You can change to the "Custom" menu and make all settings visible and customize to your hearts content. Then go to "Manage Profiles" and save the settings under a new name.
I'm not sure what you mean by a "driver". That's a WiFi printer? If so then you should be able to find it on your network. If not then print from the SD card until you understand how all the complicated stuff works.
