Posted · printing problem
Hi every one,
I have sliced my file using cura to be printed.
while printing, the printer start printing the object from the corner even if I putted them on the center when sliced.
As you can see in the picture, half of the object is printed and the other half is out of the printer bed.
Need your help to solve that
Thanks in advance
    This is a surprisingly common problem and trivial to fix.
    Go to left side of screen in PREPARE mode.  Click on your printer, then do "manage printers" then "machine settings", Uncheck "origin at center".  Also check the dimensions of your bed - for example, if it says your bed is 100mm wide but it is actually 200mm wide then it will be printing on the left half of your print bed.
