GregValiant 1,342
This is from MS 3D Builder and it is the "U" shaped hole in the middle wall. You can see that something isn't right. SketchUp is notorious for things like this. You need to take a close look at your model to make sure the surfaces aren't flipped inside-out, and other errors.
After repairing the file at an on-line service I get this...it's still wrong, but at least it's different.
This needs to be fixed in SketchUp.
The good news is that the Infill is there. Are you sure you have "Infill" turned on in the linetype settings? You can see it in the above image (but I use the sidebar GUI so my screen might be different).
tokin247 0
Matter of fact, I cannot get any infill to show up on any of my models now. That spiralize setting is off btw.
Update.
Got infill back when I went back to cura 4.13.0 although I'm still getting those shapes.
CE3PRO_Box V2.1.3mf
![cura.jpg](//content.invisioncic.com/ultimake/monthly_2022_06/cura.thumb.jpg.0875e01e63395529a4b47932adbd660d.jpg)
Edited by tokin247Link to post
