Hello Greg, mostly by sd card
But in 4.13.1 the problem is gone
Wr,Henk
Edited by SmokieHello Greg, mostly by sd card
Wr,Henk
Edited by SmokieThere were some issues with the USB Printing plugin of 5.0beta. I know it was worked on a bit but I'm not sure what changes were made.
I always print from the SD card and I haven't seen any issues with pauses. There is a setting in 5.0 (and 4.13) in the Experimental section called "Wipe Nozzle Between Layers" that can cause some movement away from the print. It has a sub-setting called "Wipe Pause". I've never used them so I'm not sure what they entail. Make sure you have them turned off in 5.0.
You can also post a problem gcode file and I'll take a look.
Hoi Greg,if turned all back to 4.13
But mabay later ill try 5.0 again and look at these setting
Fore now thanks
Wr Henk
GregValiant 742
How are you printing? SD card, Octoprint, USB?
