UM² - Gcode pilot the motor stepper of extruder?
geeks
Posted · UM² - Gcode pilot the motor stepper of extruder?
Hello,
Okay, so I wonder if Cura generates the code of the engine of the extruder.
If this is the case, I do not understand why the thread moves faster with a Cura 13.12 and much slower with Cura 14.01 file generated.
In short, I seek clarification on that side.
    In the GCode the "E" value controls the extruder. I have no idea why you would see a difference in 13.12 and 14.01, except for different settings. The engine has not really changed in this area.
    I noticed a difference in my engine speed. I do not know why!
    I can do is ziper two originals and the gcode generated file. One Cura with 13.12 and with each other Cura 14.01. Regard what can be a problem.
    To do this I take the same. STL. We will be sure to have at least the same thing.
    I hope this is not Cura..
    By what means I can transfer files for the stress test?
    What do you mean by "engine speed". In Cura the word "Engine" describes the C program that does the slicing. You can see how fast it is by watching the progress bar.
    By engine do you mean "extruder stepper motor"?
    With cura ulticode mode, the extrusion speed is set on the ultimaker in the "filament settings" or "tune" menus.
    With cura reprap mode, the extrusion speed is set by the expert settings.
    Yes!
    I tested an old file , verry good print :)
    Tomorrow I will put up a downloadable a "stress testing" on youmagine. We'll see what comes of it between 13.12 and 01.14!
    Didn't noticed any speed differences...check your settings on both versions, you must have something different...
    Yes, I looked at the settings and they are identical. ;)
    I tried to import the settings from the Gcode, and it is the same.
    Tomorrow, I would put my screens of configurations. I confess that I do not touch it too. This may be an error on my part! It's possible! I am far from knowing everything.
    Hum... If so, this is very interesting. I can´t understand why that happens, especially after read Daid's post. So as you, I am very far from knowing everything and it's the reason why this community is a very powerful tool, all our minds and experience together to improve and find better solutions.
    can't wait for further findings on this one...
    keep up the good work ;)
    I think I understand a few things.
    My nozzle does not behave as it should. This resulted a residue inside which would impede the flow of filament :shock:
    Check the course of the filament :
    - Upstream , i find the boden ( do not worry, the filament sliding is ok) .
    - Upstream, i find the stepper motor. I had trouble with the original design , the spring is a course is too limited. I keep mine and I have scratched the surface lot to make it smooth again. It's ok now.
    Since then, following a council Marrit I heated nozzle 260 for a while. Smoke out the nozzle... I went out and expelled the hand of filament extrusion. It's ok. ;)
    I revive an old file (cura 13.12 ), it works a little better.
    I will then launch two stress test .
    The first cut in 13.12 which should not be a problem. A second with 14.01 which is causing trouble.
    Maybe that originally, this is perhaps my temperature sensor is the cause of my worries. I had to redo the connections. The white wire does not stay in place. :evil:
    - If it Ultimaker² is back to normal , then this is not the gcode and it is the nozzle. A view to replace it. But anyway my extruder still suffered.
    - If Ultimaker² is not returned in normal, first see if it is a gcode problem , then see if it is a problem of nozzle. See the two ...
    I thank the community have helped me a lot when I started. This is a big plus that fact that I persevere. However, if the connection is not held, Marlin said if the temperature is weird, so I would not break other things. :)
    Now, before you launch any print, I go into my Ultimaker ² advanced mode. I look at the temperatures given by the nozzle and the plate. In general, they announced the same temperature.
    If I see too that the temperature jumps to many dozen of degree difference, I think back to check the connections. :p
    Good news. Or not!
    I just cut with the 13.12 version and I see once again that it does not advance the filament!
    I propose to look at my settings.
    Cura1312 Parameter Pge1
    Cura1312 Parameter Pge2
    Cura1312 Parameter Pge3
    Tell me if I'm wrong.
    Good!
    I have able to get out, finally, something.
    1312 Imp
    1401 Imp
    Comparatif Imp
    The settings look good. Bluidplate height appears to be one of the causes, as the extruder.
    The first prevents extrusion.
    The second chipping away the filament.
    I think I need to replace the extruder now and how to adjust the buildplate correctly. I Callback support (open ticket) including Marrit to show him the subject and suggestions.
    Thank you for your help. It is perhaps not too late. :)
