Posted · CURA5.0について
印刷の設定の所で、カーソルが当たると左側に説明が黒バックで出ますが、その説明の所をスクロールする方法って有りますか?
    I thought that was fixed in the stable version of 5.0.  If not then it will be fixed for the next release.
    If you go to the Marketplace there is a "Settings Guide" plugin.  After installing and re-starting Cura - when you right click on a setting the explanation comes up.
