please I'm missing the same thing
[google translate to english by gr5]
But on your download site (https://ultimaker.com/de/software/ultimaker-cura) you have an ad with this......
Öffnen Sie native Autodesk Inventor-Dateiformate in Ultimaker Cura.
If you have a "professional" Cura subscription, you can use the official Ultimaker CAD integration plugin. That is what that blurb refers to. There are two plugins:
* A free plugin, which sofar is not available for Cura 5.0 and newer, and which requires the CAD application to be installed on the system
* An official Ultimaker plugin, which is only available for paying customers, and which works without the CAD package to be installed.
ahoeben 1,955
With the release of the Cura 5.0 beta, a lot has changed in the core of Cura. So much so, that in order to be compatible with Cura 5.0, all plugin need to be updated and resubmitted to the Marketplace. @thopiekar, the author of the Inventor plugin for Cura may not have had the time to make the necessary changes.
