Posted (edited) · How to reset print settings
If you click on the Settings Profile Name and then go down and re-select the same profile, a dialog should come up asking if you want to Discard changes or Keep the changes.  When you "Discard" then the settings will go back to however they were defined for that particular profile.
Edited by GregValiant
