The only portion of your part that is touching the print bed is under that one "arm" or "leg" or whatever you call it. The blue area is what is called a "skirt" and it should go all the way around your part. It has 2 purposes - one is to purge the nozzle and get the filament flowing nicely. The other is to check leveling to see if you have good leveling all the way around the part (for example sometimes the rear of your bed is a bit high or low and you can see this while it's printing the skirt and you can adjust the knobs to fix this before it starts printing your actual print).
If you don't fix this issue that the bottom of your part isn't flat you will get a horrible first layer as it won't print most of your part and then as it prints the second or third (or whenever it gets to your part) level it will be printing the bottom of your part mostly in thin air.
1) one fix is to just set the Z value for your part to be slightly negative. Click on the part - select the move tool on the left and then for the Z value try -0.5mm at first and slice and if that works well lower that value closer to 0 until it just works nicely such that it prints all of the bottom of your part. Of course this will change your final dimensions by the negative value. Oh - before you can do that you have to set the following setting - go to menu "Preferences" "Configure Cura" and then uncheck "automatically drop models to the build plate".
2) Another fix is to click the part, choose the rotation tool and then select the "lay flat" button. This might work. It will try to tilt your part enough so it is touching as flat as possible. Although I'm suspicious this won't work.
3) Another fix is to fix the model in tinkercad. That one post is slightly lower than the others. Maybe you can fix it? Maybe all the posts are at different heights so maybe it will be a pain in the neck. I don't know without seeing the model itself.
gr5 2,229
The bottom of your part isn't perfect flat/level.
