That will need to be done. In addition, I would bring a calibration cube into the existing Cura installation, select the printer and a Settings Profile, and use the "File | Save Project" command to create a 3mf file. Do that for each profile you want to save.
In your new installation you would open each of those project files and the Printer, Model, and Settings will be imported. It would be a safeguard in case something doesn't carry over when copying the AppData folder.
If you have customized your StartUp or Ending gcodes of your printer then you should make up a 3mf file for sure as the new installation might install a printer from the stock definition files. You could possibly lose any customizing you have done.
GregValiant 1,112
