Extruder 1: Custom PLA Green - empty
Princy557
Posted · Extruder 1: Custom PLA Green - empty
Using Cura 5 and GEEETECH A20T.
Two main questions:
1. when I look at settings by right clicking on the Nr 1 top left of snap. All my extruders show empty. Why? What can I do about it?
2. on my A20T, even though I have chosen the suggested GREEN as shown, the actual printer gives me a mix of 33%/33%/34%. Why? and h ow to get it to show the actual chosen filament?
Note: for anyone who's seen me here before. I'm on my second A20T as I had so many hothead problems with them failing I bought another. (Stupid me by the looks of it). My second one has started to show in the same way with little failures,, getting worse until the heating gives up completely. Only upside is I know the A20T inside out ha ha.
    Posted (edited) · Extruder 1: Custom PLA Green - empty
    Additional info:
    When I print the mix is always 33%,33%,34%.
    Even though I have set up my three PLA Green, white ,and black.
    I have one heater, three extruders.
    Is there a profile GEEETECH A20T for the Cura 5?
    A better question might be. Why is my GEEETECH A20T not printing the set up colours I select. When I select the white, the item changes to white, when I select black the item changes to black ditto with the green. but dont print other than mixed
    Regards
    Edited by Princy557
    missed a word & Question
    The commands that control the mixing might be in your StartUp Gcode.  I think they would be M163 to M166.
    Your "real" extruders are T0, T1, and T2.  If your StartUp Gcode ends with T3 or higher then it's calling for your "virtual" mixing extruder at the start of a print.  Cura looks at the startup gcode as "That's what they want then that's what they're getting.".  If your startup gcode ends with a "T" command try "T{initial_extruder_nr}".  Cura will note that and replace the keyword with the extruder that starts the print.  (the Curly brackets are required.)
    In regards to the "empty" sign...have you picked nozzles for each extruder?
    Edited by GregValiant
    Hi GregValiant,
    Duh!, thanks, staring me in the face wasn't it.
    As for "empty" sign..... Each extruder has a 0.4 mm nozzle chosen, but still shows up on the Cura menus (previous picture) as being Empty.
    I now  have it printing the colour that I have chosen . WINNER
    Thanks again
    Regards
    If you have the "Printer Settings" loaded from the MarketPlace - check the nozzle diameter for each extruder.
    The nozzle diameter should also be present in the Machine Settings for each extruder.  Odd that it isn't showing up in that dialog box.
    I  have three areas 1,2,3...
    Bottom left
    Upper Middle
    All show the same  empty.
    Strange
    The missing one....
    Edited by Princy557
    additions
    Hello,
    I feel to have the same issue with GEEETECH A10T  which is smaller that the A20T but also built with three extruders on a single nozzle.
    I tried to fix the issue through the gcode :
    ;FLAVOR:Marlin
    ;TIME:23401
    ;Filament used: 0.00883381m, 15.7565m, 0m
    ;Layer height: 0.15
    ;MINX:135.091
    ;MINY:125.738
    ;MINZ:0.15
    ;MAXX:203.615
    ;MAXY:239.262
    ;MAXZ:33
    ;POSTPROCESSED
    ;Generated with Cura_SteamEngine 4.8
    T0
    M104 S200
    M104 T1 S175
    M105
    M109 S200
    M105
    M109 T1 S175
    M82 ;absolute extrusion mode
    G28
    G1 Z15 F300
    M107
    G90
    M82
    M104 S200
    M140 S55
    G92 E0
    M109 S200
    M107
    M163 S0 P0.00
    M163 S1 P0.50
    M163 S2 P0.50
    expecting to have a mix of 0, 50% and 50%  (see the 3 last lines )
    ...but ... the printer did not read that info and worked exactly as if the code did not exist, printing according to the previous config (which has been set through the printer menu and options - « Prepare - Mixing »  )
    I'm sure that file has been red, because the nozzle temperature has been changed according to what the gcode file shows.  So why can I adjust the temperature and not the colors ?
    As you all, I could find nothing in the Cura (for Linux) software to achieve that goal.
    Thanks.
