DivingDuck 94
The picture I attached above was from 5.1 beta and I did check it for 5.0 as well.
Oh, I forgot to mention settings visibility. I just took a look on Manage Settings Visibility and recognize in my installation at least one setting was unchecked.
If this isn't the case someone from UM needs to jump in because now I'm out of ideas 🙂
The "Support Bottom Distance" setting only makes sense if the "Support Placement" setting is set to "Everywhere"; it will not show up when that setting is set to "Touching Buildplate", because then there will not be any support bottoms touching the model.
1
2
DivingDuck 94
Still a lot to find out and learn again with the new 5.x versions of Cura. Thank you @ahoeben
2
35 minutes ago, DivingDuck said:Still a lot to find out and learn again with the new 5.x versions of Cura.
This particular thing has been the same for the past 6 years though 😉
PS: I'll admit that I had to look up why the setting would not be showing in the fdmprinter.def.json file.
Edited by ahoeben-
2
Thank you both!! I set the placement as everywhere and the setting is visible now, thank you so much!!!
1
- 7 months later...
Thank you one and all - so easy to get zoned in on the details and miss the obvious!
DivingDuck 94
You will find it if you put only support in the search field.
