Posted · Blobs on print
Hi, I keep having this problem hope someone can help. I need to print thin walls and keep getting these blobs marked on white on the slicer. I adjusted the seam, retraction settings, coasting, but don't know why this keeps happening or how to fix it.
    White marks are start marks.  I'm no pro but this means when it's recovering from retraction it is extruding too much.  if you've done all the obvious stuff and it hasn't changed perhaps look into retraction extra prime amount and retraction prime speed. Setting a negative value can help w/ that if nothing else can.
