Load the model in Cura. Set the "Infill Density" to 100% and slice.
You could also set the "Wall Count" to a very high number (50?)
You could set the "Top/Bottom Layers" to a high number (500?).
Any of those would achieve the same result. The difference would be in the extrusion pattern used on the inside.
The best file to troubleshoot with is a project file. It will contain: your printer, the model, and your current settings. You can produce one by using the "File | Save Project" command in Cura. Then post that 3mf file here.
GregValiant 1,322
