Thanks. I am trying to locate the installer in the files without any success. Do you where I can find this?
In my Ultimaker 5.0 Cura folder there is nothing showing even after opening folders.
The process is very different for windows, linux, or Mac. What operating system are you using?
In Windows, the installer itself has a long name like:
Ultimaker-Cura-5.1.0-win64.exe
and is typically found in a "download" folder but you can specify where your browser saved it.
Whereas (at least on windows) Cura has a much shorter name like:
Cura.exe
And is typically in a folder like "c:\Program Files\Ultimaker Cura 4.8.0\Cura.exe"
On Linux there is no installer and you always run the file that ends in ".AppImage".
I could be totally wrong and maybe you are indeed running cura and somehow (somehow? ) it tries to reinstall itself? Seems far fetched.
I will try that. Thank you very much, I appreciate your help!
what operating system are you using?
gr5 2,243
I think you are clicking on the installer? After you have installed cura, make sure to delete the installer (the file you downloaded).
