Cura not slicing holes correctly
Geezy
Posted · Cura not slicing holes correctly
I am trying to make a meter plate for a 5 gang box. Im very new to the space and am still learning. Cura is filling in some holes while leaving some holes on my print when I slice the stl file. I used the boolean modifier in blender for the 4 holes that are not being cut out. The two holes correctly sliced were from a previous design I found online that I modified. I also used the boolean modifier for the meter box cutouts. Thanks for the help in advance!
Meter Plate.stl
    Hi @Geezy,
    the normals look odd, if you import the stl file back into blender. Normals are flipped on half of the  faces.
    I assume that's the main problem. So... i would check (and fix) the normals in blender before exporting to stl.
    And these supplementary faces should probable not be there at all?
    Enable viewport overlay "face orientation":
