GregValiant 1,346
You have "Infill as Support" enabled. That leaves a hole in the center of the infill because there is nothing above it that requires support.
The button to the right of the "settings search" box is the "settings visibility" tool. Click on it and set the visibility to "All". When settings are not visible they are out-of-site and out-of-mind. If you happen to make a change for a particular model it's easy to forget you did it and then it affects the next model you slice.
The model on the left has "Infill as Support" enabled as a Per Model setting.
- 1
That was it!
Thanks so much for your help!
Framar 38
Can you post the 3D solid file. I would like to have a look at it.
9uillo 0
v1.2.obj
