But how do I get rid of it tho
I can't really figure that one out either
I don't know MeshMixer. If I need to alter a STL file I use MS 3D Builder which is bundled with Windows 10 (and I think Win11).
Depending on how you want to change the STL you could also use Cura's Support Blockers. They can be configured to do different things by changing their Per Model settings.
GregValiant 1,322
Depending on how you or Meshmixer left the edges they could be open. If they are then your model is not watertight and won't slice or print correctly.
You can use the Mesh Tools plugin from the Marketplace to check your models.
