Would it be fair to ask a question on a non Ultimaker printer?
Posted (edited) · Would it be fair to ask a question on a non Ultimaker printer?
I have a Creality Ender 3 s1 pro. It has 2 jack screws (threaded arms) on each side of the vertical braces. The extruder rides on a rail that has a knob to tighten the belt at the back running horizontally. The threaded arms control the vertical motion. At the very top of the arms is another belt running from one arm horizontally to the other. This belt has no tightening knob and is loose. It should be snug. just wanted some help before I mess it up.
Thanks
Edited by 3AM
    Posted · Would it be fair to ask a question on a non Ultimaker printer?
    Here I have included a chart for an Ender 3 s1 Pro. P.S. it is not cheating. actually i have questions about my Monoprice Ultra almost every chat. I just have the app for Cura.
    Better?
    can you see it??
    1 hour ago, FaithV said:
    here, I'll send it again...
    for Ender 3 Pro Upgraded Version Creality 3D Printer Kit | eBay
    This is a picture of stepper motor located on the base. Not the belt that runs across the top from side to side
    but thanks anyway
    so sorry, I will keep researching until I find a blue print for this part. Is there a small like parts map in your manual?
    totes fine if there isn't, sorry I didn't read that properly...
