When I started Cura I got two consent forms then Add a Printer. I couldn't see any way to proceed without a printer to connect to. Now I've been more persistent. By going the Non-Network route I've discovered that it only needs to know what kind of printer to work with, it doesn't actually need a printer to connect to. I can get going now. Thank you.
2
IRobertI 521
Can you give us some more information about what you mean when it wont start without connecting a printer? Do you get some sort of error message?
You should be able to use Cura without having a connected printer without any problem.
