Selling my Ultimaker Original printer__$75
Posted (edited) · Selling my Ultimaker Original printer__$75
I'm selling my Ultimaker Original+ for only $75 plus shipping. I don't use it anymore and I don't want to keep it mothballed. I'm trying to free up space in my workroom. I don't want to just toss it away, which is why I'm selling it so cheap. I'd like to see it go to a good home. It worked great the last time I used it, but it does need some TLC.
Edited by eberle
    The printer is an Original Plus. It was running great the last time I used it. However, it needs a new nozzle. It is not self-leveling so that can be a chore. You'd probably want to print out new bushing blocks, which is easy to do. Thingiverse has a bunch of them to pick from. Also, one of the wires gong to the hotend is connected outside of the hotend mount.
    I'd really like to see this go to someone who will use it, which is why I'm selling it so cheap.
    Edited by eberle
    Do you know if the board allows for dual extrusion? And where are you located?
    Edited by 3dprntz
    Posted · Selling my Ultimaker Original printer__$75
    You cant do dual extrusion on the UO+.
    I am located in Buffalo, New York in the USA
    Do you know how much would be shipping?
    What is your zip code and I'll find out.
