GregValiant 1,320
In the Experimental section see if you have "Wipe Nozzle Between Layers" enabled.
Another setting that can give that behavior is in the Cooling section called "Lift Head".
1
This is a video of the travel...
20 minutes ago, GregValiant said:In the Experimental section see if you have "Wipe Nozzle Between Layers" enabled.
Yep thanks for that it was the "Lift Head" setting. I will see if it makes any difference to my print now... interestingly it halves my print time from 10mins to 5 mins...
Thank you for sharing the guyz, I am also stuck in the same problem.
Edited by SimonGeorge
Badgersurfer 2
I have moved the workpiece to the center and the travel lines have moved accordingly . So it seems the nozzle is doing something that is aligned with the centerpoint on the X-axis. I thought maybe this may be to enable it to retract and extrude for the next layer? I have set retraction off and there is no difference.
