@nallath I believe you're right... I turned off bridging and the gaps are now gone. I don't this a good design, because there are times when you would really need true bridging, unless you can control those gaps when bridging is on.
This is with bridging turned off:
Edited by NewtronGregValiant 1,322
Hello @Newtron.
You will notice that the Bridge Settings are in the Experimental section, and yes, they are still being tweaked.
There are certain rules to using the bridge settings. A couple of them are:
- If you are printing over support then bridge settings are generally not required.
- If your feature is a "balcony" cantilevered off the model then you can't use bridging as there is no far-side buttress to adhere to.
- If the feature has a radius/curve along one edge then you likely cannot use bridging.
The bridge settings come in handy when you need them, But they aren't something that is always required or advisable.
Thanks @GregValiant
nallath 1,123
Could be that it's trying to bridge. Could you share your project file?
