Standard (expert) settings for Skirt are:
Line count: 1
Start distance (mm): 3.0
Minimal length (mm): 150
That means it will make at least 1 line around the model. If that results in more than 150mm length, then the skirt is done. If it's less than 150 mm, it will make more skirt lines until the total length reaches 150mm. I like that, because that way it doesn't make a difference whether if you're printing a large or small model.
I changed the minimal length setting to 300mm which, until now, has always been enough to compensate for the delayed extrusion.
But I haven't been using Skirt for a long time now - brim is usually the best choice. Never used a raft either. With brim, you'll just get about 1-2 lines less (...because extrusion doesn't start instantly), but that doesn't make much of a difference...
Sometimes I also start a print, let it run until the extrusion is good, then stop, quickly clean the build plate, and restart. But that's not really necessary, I'm just over-cautious
/edit:
That's of course assuming you are using Cura and not another slicing software
IRobertI 520
You can change the parameters of the skirt in Expert -> Open expert settings. Also, have you tried using a brim instead of a raft? I've been printing now for 2-3 years and I haven't used a raft yet.
