Possible bug in "Select face to align to build plate"
ac2022
Posted (edited) · Possible bug in "Select face to align to build plate"
Hello!
I'm really new to Cura, so perhaps I just don't get it, but on the other hand, the following looks like a bug to me.
I have recorded a video here:
There is a text on the object to indicate which side is just shown:
In the video, you can see how I try to use the  "Select face to align to build plate" tool.
I click it to activate it, then I click the face that I want to use.
The first few clicks, it doesn't work, so I try it again and again.
I select and deselect the model.
Then, finally, it works.
You can see how the text disappears (this means that the other side is now shown).AKMAX_joycase t2 v1.3mf
The model is attached.
I can reproduce this behaviour.
Thanks for your time.
Edited by ac2022
    • ac2022 changed the title to Possible bug in "Select face to align to build plate"
    • 1 month later...
    Posted · Possible bug in "Select face to align to build plate"
    You can write up a bug report on the GitHub site.  The developers check it often.
    I don't have the option for that function as I'm in compatibility mode so those buttons aren't there.  I've learned to live without it since I've never had it.
        • 24 replies
