GregValiant 1,318
"My Anycubic Chiron can print XY 400mm x 400mm on its glass 410mm x 430mm build plate."
The physical size of the build plate, and the actual Printable Area are two different things. Since your model is line-to-line to the limit of the Printable Area in the Cura Machine Settings - Cura won't slice.
Anycubic has provided a 5mm safety area on the left and right, and a 15mm safety area along the front and rear.
If you go into Manage Printers and then Machine Settings and change the build plate size to 405 x 405 the model will slice and it will fit your build plate.
There are really several settings involved in this (Home Offsets, software end stops, etc.) but for a single model the above should work and should print properly.
cnd 2
P.S. No - I cannot go diagonal, and yes, I absolutely do need that very last millimeter (it's for a laptop HEPA filter holder, and I need to put a silicone sock on this to make an air-tight seal below my laptop, which is (grr) precisely 400mm...)
