Is there a way to add a thumbnail image to G-code in Cura?
Go to solution Solved by nallath,
Posted · Is there a way to add a thumbnail image to G-code in Cura?
Is there a way to add a thumbnail image to the G-code in Cura 5.1.0?
If so, how can this be done?
Would the thumbnail be generated by Cura
or do I need to supply an image (.jpeg or .png, etc)?
What size does the thumbnail image need to be?
Thanks in advance for anyone's help - Most appreciated!
AF
//end//
    • 1 month later...
    Nallath,
    Thank you for help!
    Not sure how I missed that in the list of extensions. It worked perfectly.
    TIP:  For all using Windows, install the PowerToys v0.64 found here:
    https://learn.microsoft.com/en-us/windows/powertoys/install
    The power toys has a windows explorer (File Manager) previewer for GCODE, STL and a few other types.
    For gcode you have to have a thumbnail in the code. Hence my initial question.
    Thanks to Nallath, I can now see the preview in windows as well as the 3D printers display!
    Thanks again,
    AF
    • 1 year later...
    2 minutes ago, MCMLXXXII said:
    Have a nice day !
    My thumbnail does not appear on Btt TFT35 v3.
    Cura 5.6
    Make sure you're using the Create Thumbnail post-processor (go to Extensions > Post Processing > Modify G-Code and click Add a script)
    But on a lot of newer printers the thumbnail creation in Cura doesn't work because they use a different format to what Cura produces. Try looking around to see if anyone has produced a script or written instructions for your printer, but be ready to accept the possibility that it just ain't gonna happen (like I haven't found a working way for my Ender-3 V3 SE... although not even Creality Print includes thumbnails half the time, so it's definitely not a Cura problem).
