Thank you for your reply.
cura version: 4.13.0
system: windows 10
settings and gcodes in the slice_data.zip
UMS5_300X300_CURA.gcode & UMS5_300X300_CURA.html --> CURA 4.13.0
300X300_20220922_155354_0.gcode & CurrentPrintSetting.html --> ENGINE 4.13.0 Command line
The problem screenshot is as follows:
Please help see where the problem causes, thank you
MariMakes 178
Hey @vegeta
Welcome to the Ultimaker Community 🚀.
Can you share a little more about your set-up?
What operating system are you on?
What printer are you slicing for?
What Cura version are you using Or are you running from Source?
Perhaps share your problem as I see .... but I expect .....
We can use that to help you better. 👍
