here you go.
GregValiant 1,330
This one is with "Wipe Nozzle Between Layers" enabled in your 3mf file (it's in the Experimental section).
And this one is with it disabled.
I suggest you always start out a Cura session by using the Setting Visibility tool (to the right of the Setting Search bar) and set the visiblity to "All". Sometimes you need one of these settings ("Remove all Holes" and "Make Overhangs Printable" are favorites) and then forget about it and they remain enabled and your next project is wonky. If a setting is out of sight it's out of mind.
Edited by GregValiantI actually had the wipe nozzle between layers enabled.
I disabled it and re-sliced and I think it's working now.
I'm reprinting now so we'll see how it goes but I think it should be good now.
TBH, I'm not even sure why I had it enabled in the first place.
Thanks for the help.
Edited by finity69x2
GregValiant 1,330
A couple of example files would help.
Load a model with your settings profile that causes this and then use "File | Save Project" and post the 3mf file here. It might be helpful if you would also post one of the "bad" gcode files.
Settings like "Lift Head" and "Wipe Nozzle between Layers" can have this effect.
