4 hours ago, ahoeben said:You can not "edit" the materials that come with Cura. They are "read-only". You can "duplicate" those read-only materials, and edit the duplicates. This is the same for Ultimaker materials by the way.
Thanks for the response but that you wrote I know. If I use an filament other then Ultimaker which requires 240 degree core temperature, how do I adjust this temperature. Yes its possible to do this when the printer is idle but at the moment it receives the order to print the temperatuur goes back to the standard temperature.
ahoeben 2,047
