GregValiant 1,330
I've noticed that odd behavior myself.
There were several bug reports made on Github (regarding Cura 5.1) and the Concentric patterns when used as skins, infill, ironing, and support. This "not putting the layer down ring by ring" was one of them. When there are travel moves on a top skin there can be scars from the travels. On the bottom, not so much - unless there is some oozing during the travels.
Hey @joegatling,
Welcome to the Ultimaker Community 🚀
This seems to be related to a bug in ordering the concentric initial layers.
If you select a different initial layer pattern it should work better. We are aware of the issue, it's also reported here https://github.com/Ultimaker/Cura/issues/12977
We have a ticket to the backlog with the intent to improve this.
I'll add your model as a testcase for our testers.
Thanks for the report! 👍
- 5 weeks later...
I've also noticed this issue with skirts on 5.1.0 The single skirt line would move back on itself lifting from the build plate and cause issues with my prints. Glad to hear that it is on the fix list for future development. I never had this issue in 4.13. Thanks!
GregValiant 1,330
I haven't seen the problem in 5.2.1 at all. Nice job by the Cura team.
I'd buy them a round of "Likes" but there is only the one button.
joegatling 0
UPDATE - I just downloaded the 5.2.0 beta and the same model slices properly now. I can't see this particular issue called out in the build notes, but there is a mention of brims printing in the wrong order. Perhaps it is related to that.
