Posted · Cura 5.1.1 Start gcode
Hi I am new to Cura I am trying to maximize my print times and I change my start gcode in Cura but for some reason when I slice and go to print the bed temp and nozzle temp go way to high but if I save the gcode then manual edit the start gcode it runs fine.
 This is the start gcode I would like to run
; Ender 3 Custom Start G-code
M117 Pre-heating the extruder!
M104 S170; start warming extruder to 170
M140 S60{material_bed_temperature_layer_0} ; Set Heat Bed temperature
M190 S60{material_bed_temperature_layer_0} ; Wait for Heat Bed temperature
G28 ; Home all axes
G29 A ; Activate bed mesh -level (CR-Touch)
G29 L0 ; Load mesh from slot 0
G29 J3 ; Probe for bed tilt
G1 X245 Y218.5 Z1 F5000.0
G92 E0 ; Reset extruder
M104 S215{material_print_temperature_layer_0} ; Set Extruder temperature
M109 S215{material_print_temperature_layer_0} ; Wait for Extruder temperature
G1 Z1.0 F3000 ; move z up little to prevent scratching of surface
G1 X225 Y200 Z0.3 F5000.0 ; move to start-line position
G1 X225 Y20 Z0.3 F1500.0 E15 ; draw 1st line
G1 X222.2 Y20 Z0.3 F5000.0 ; move to side a little
G1 X222.2 Y200 Z0.3 F1500.0 E30 ; draw 2nd line
G92 E0 ; reset extruder
; End of custom start GCode
    A line like this:
    is wrong.  What is happening is Cura is adding your bed temperature and so the line becomes
    M140 S6060
    and the hot end becomes
    M104 S215215
    Which is probably a tad on the warm side.
    So change those 4 lines that have the replacement words in them and remove the numbers after the "S"
    M140 S{material_bed_temperature_layer_0}
    M104 S{material_print_temperature_layer_0}
    Your M104 S170 line is fine since nothing gets added too it and the nozzle shouldn't ooze at 170.
