Posted
· Why does changing the material not do anything?
No, a material profile is independent, but it will set a few parameters in your profile (Colorfabb PETG)
The idea behind is that you have different profiles, like draft, normal, fine, independent from the material. When you then select a material, parameters like print temperature, bed temp, retraction and so on will be used.
But I don't know the priorities out of my head, so could be that when you have a print temp set in your profile, that one has a higher prio than the one in the material profile.
Smithy 1,145
