4 hours ago, GregValiant said:If you have "Support Placement" set to "Everywhere" then check settings like "Minimum Support Area" and "Support XY Distance".
There are a lot of support settings (73) and some can change whether or not supports are applied to certain areas.
If you use the "File | Save Project" command and post the 3mf file here some one will take a look.
Hey Greg! Thank you for the help! I've enabled those and am seeing different support structures rendered, however not inside the model where my custom supports (previous screenshot) are intended to be rendered. Check my screenshots for some help and clarification.
Settings:
Model with these settings:
Mind my reluctance to post my 3mf, as I'm sure it will very quickly rectify my issue -- I paid for this model, however 🙂 My wife appreciates the help! These are the table-top succulent planter holders for our baby shower.
Many thanks!
GregValiant 1,330
