GregValiant 1,320
You can use Search and Replace. M221 is the global flow rate and the "S" parameter is %.
This would change all flows to 100%.
Search = ;LAYER:1\n
Replace = ;LAYER:1\nM221 S100\n
Use regular expressions = Checked
That would result in this within the gcode:
;TIME_ELAPSED:43.906829
;LAYER:1
M221 S100
"backslash+n" is the newline character and is required as shown. Search and Replace accepts multi-line replacements.
