Dim3nsioneer 557
Newer Marlin (firmware) versions have a more comfortable sound programmed. You get it e.g. via marlinbuilder.robotfuzz com.
Wow, mysterious. I always assumed that the sound wasn't implemented. I guess my Ulticontroller had a broken piezo right out of the box!
Luckily I prefer a silent printer.
@Daid: sounds good I think that's it for me
btw: do you have any comment to this question? http://umforum.ultimaker.com/index.php?/topic/4535-calculating-required-filament-in-layers-view/
@Dim3nsioneer: thanks for the hint, but that's a little bit too dangerous I think - never change a running system . May be I will try it later...
@Nick: You're a lucky one
Thanks for your replies.
Cheers,
Joerg
just to make this thread useful for others in future:
As I were going to connect my raspberry with my UM1 it came to my attention that I have to change the firmware and I visited the link from Dimensioneer.
There I just change the Baud rate for the connection and put the new firmware on my UM. After that the sound was pretty quiet. So there ist no button or slider to regulate the volume - just the firmware from the Marlin builder and everything is fine - perfect solution
Thanks to all.
Daid 306
Piece of tape on the buzzer does wonders for the volume ;-)
