GregValiant 1,330
No problems.
In that Project File "Generate Support" is not enabled. A team member will need to know exactly how you had the slice set up.
No problems.
No It was not enabled before but I enabled with normal support structure and sliced again later on. It was a successful print. However, I don't like this solution, I don't want to resort to using support whenever I come across this type of situation. I'd like a better solution without support, support means complication and mostly needs cleaning up a mess.
Maybe I didn't understand you very much, is this what you mean? Why would a team member like to know my slicer setup in spite of the project file being already here? Sorry if I didn't get you well.
The information provided by any poster must be as complete and concise as possible. I saw in your screen shot that support was enabled but the project file said it wasn't. We've had project files submitted here that were totally different than what the poster was talking about. Even the model was different. It's hard to give advice or troubleshoot when we are talking about apples and the poster was talking about oranges.
Support is often required. I have a special set of tools for support removal and it can still be a PITA.
To eliminate support you sometimes can alter the model. In this case if it is printed as two separate pieces and glued together then neither piece needs support. With a little hole in the middle of each half, a piece of filament can be glued into one half and it becomes a locating pin for gluing on the other half. I used a cylindrical support blocker configured as a cutting mesh and placed them in the center of each model. One model prints right-side up but buried into the build plate 6mm. The other model prints upside-down with only 6mm sticking up. It will print without support and cyano-acrylic Super-Glue works really well on PETG (and PLA).
This is an x-ray view and you can see the 2.2mm diameter x 4mm long Cutting Mesh support blockers that are at the centerline of each half. As a cutting mesh they will leave a hole.
Here is the normal view
So there are things you can do to eliminate support but sometimes support is the best way to go.
Here is a project file so you can see what I did. Sometimes multiple locating pins are required. Sometimes the model needs to be altered in a program like MS 3D Builder. Sometimes you get stuck with support.
Edited by GregValiant
On 11/3/2022 at 1:10 PM, GregValiant said:The information provided by any poster must be as complete and concise as possible. I saw in your screen shot that support was enabled but the project file said it wasn't. We've had project files submitted here that were totally different than what the poster was talking about. Even the model was different. It's hard to give advice or troubleshoot when we are talking about apples and the poster was talking about oranges.
I think there's a misunderstanding, neither in my screenshot nor my project file has support enabled, but this is not a problem of course, I understand you now. I will pay attention to those details you mention in the future. Thank you.
On 11/3/2022 at 1:10 PM, GregValiant said:Support is often required. I have a special set of tools for support removal and it can still be a PITA.
To eliminate support...
I will take your method into consideration whenever I encounter this problem in the future. They are very much helpful, thank you really.
GregValiant 1,330
You need to turn on Support.
I'd do it this way...
GV_lid.3mf
cagatay117 0
Thank you @GregValiant, I printed with support. But nevertheless, I'd like to know if anything can be done and wait for other responses from the forum people.
