Hi Mari,
Still get the Invalid File message with your version of file.
Pat
Hi Mari,
Pat
Hey @CuraCpat,
Could it be that your 3mf reader is disabled?
You can check this by opening the marketplace and click the gear icon.
On 11/2/2022 at 4:47 PM, MariMakes said:Hey @CuraCpat,
You can check this by opening the marketplace and click the gear icon.![]()
It still isn't working the plug ins you mentioned are enabled. I am on the mac (M1 chip) by the way.
We need to see your logs. See this article about where to find them, and post a link to them here.
16 hours ago, ahoeben said:We need to see your logs. See this article about where to find them, and post a link to them here.
My bad, cura.logis this good? Hopefully you guys can solve it, because I can't export my profiles as html either.
It looks like you tried loading a file named "3DBenchy_ePA-CF.3mf 3" a couple of times. Note the space and number three after the .3mf extension. Those should not be there. Perhaps you meant to rename the file to "3DBenchy_ePA-CF 3.3mf" (ie: with the added 3 before the extension)
You successfully loaded a freshly downloaded "3DBenchy_ePA-CF.3mf" later.
MariMakes 201
Hey @CuraCpat,
Strange 🤔 I dragged your file straight into Cura and The model loaded for me.
I exported it again. Can you try this file?
Mari_Disk.3mf
