Cannot load 3mf files in Cura 5.2.1
CuraCpat
Posted · Cannot load 3mf files in Cura 5.2.1
On 11/2/2022 at 4:47 PM, MariMakes said:
Hey @CuraCpat,
Could it be that your 3mf reader is disabled?
You can check this by opening the marketplace and click the gear icon.
It still isn't working the plug ins you mentioned are enabled. I am on the mac (M1 chip) by the way.
    We need to see your logs. See this article about where to find them, and post a link to them here.
    My bad, cura.logis this good? Hopefully you guys can solve it, because I can't export my profiles as html either.
    It looks like you tried loading a file named "3DBenchy_ePA-CF.3mf 3" a couple of times. Note the space and number three after the .3mf extension. Those should not be there. Perhaps you meant to rename the file to "3DBenchy_ePA-CF 3.3mf" (ie: with the added 3 before the extension)
    You successfully loaded a freshly downloaded "3DBenchy_ePA-CF.3mf" later.
