Thanks for the advice and yeah, I don't think it is seaworthy! I will look all of that over and see if I can get somewhere with this.
I did mention in my initial post that I have always returned to the initial setup if the changes haven't worked so I have been working from that baseline but from what you say, it doesn't sound like I have been working from the correct baseline. I will try your advice tonight when I get home from work.
Thanks again!!!
Edited by jman31
GregValiant 1,144
That's really bad. I'm a long time boater and I can tell you right now that holes along the waterline qualify as a "Bad Thing".
Your item #5 really sticks out. The printer is capable of putting out good prints. Cura is a good slicer. I think it's time to go back to square 1 with your settings.
Set Cura up with bland normal settings. 205 print temperature, all flows at 100%, all line widths at nozzle width, print speeds the same for all the different features, You need to give yourself a baseline to work from and then you can make incremental adjustments. If the printer is working correctly then normal settings will print a decent Benchy.
Cura doesn't actually support IDEX printers as it only uses X and Y axis, but it can be made to work. Did you do a search here for "FlashForge"? The topic has come up before.
THIS POST seems to have some info including StartUp gcode and Extruder StartUp gcode.
If you have FlashPrint loaded then slice a model in each of the three modes (normal duplicate, mirror). And take a look at the beginning of each gcode. The "Raise3D" IDEX printers have specific gcode commands to tell the printer which mode to use (M605 S0, S1 or S2). By installing that printer 3 times in Cura with the proper gcode command in each printer's startup gcode, a user could achieve all three functions. If they want "Mirror Mode" then they select their "Mirror" printer.
Edited by GregValiantLink to post
