Thank you GregValiant.
I checked the Combing Mode setting. It is "all on".
I looked at the head movements in the simulation. Obviously my guess about the head going over the cavities was wrong. The movements seem to be OK in Cura.
The hair still appears?! Can it be that the printer optimizes the movements and then makes the direct path through the cavity? Very strange.
I've attached a picture of the "hair". This is very fine and dense hair that is difficult to remove.
GregValiant 1,330
Figuring out which "Combing Mode" to use is the usual fix. Adjusting the "Layer Start" X Y in the Travel section and the "Z seam Location" in the Walls section can help as well.
