- Solution
Is it possible to print support inside a "hollow" object ? (Using the minimum infill for supporting overhanging parts )
Thank you for your answers.
Nosybottle, I think that might be the solution but it will take me some time to understand and try this settings. I will post later to tell you if that worked.
Ok, done. Lightning infill was what I was looking for. Thank you
- 1
GregValiant 1,318
Being able to use water soluble PVA supports is a primary reason to go to a dual extruder machine.
You have considered a split mold? You have to get the part out somehow.
