I have attached the .3mf.
Currently using Overture easy nylon, heat 217, speed 60mm, extrusion 99%, .6mm hot end. New hot end as of yesterday, been an issue prior. Checked nozzle and is sunk to base. Ill try heat next if you don't see anything else.
GregValiant 1,489
Load one of your models and set Cura up to slice. Then use the "File | Save Project" command and post the 3mf file here.
Usually 3 walls will keep infill from showing or leaving marks. It can be affected y a lot of different things from under-extrusion to a loose hot end. Post the project file and maybe looking at it will at least eliminate some things.
