Cura 5.2.1 showing only Super/Ultra quality profiles with Ender 3 Pro
billla
Go to solution Solved by ahoeben,
Posted (edited) · Cura 5.2.1 showing only Super/Ultra quality profiles with Ender 3 Pro
Since upgrading to 5.2.1 Cura no longer shows the full list of standard profiles. These were present in all prior versions. The only profiles showing are Ultra Quality and Super Quality.
I added a second Ender 3 Pro printer to the configuration, but it showed the same 2 profiles.
Edited by billla
    • Solution
    Posted · Cura 5.2.1 showing only Super/Ultra quality profiles with Ender 3 Pro
    What nozzle size do you have selected in Cura?
    With a 0.2mm nozzle, you can only print thin layers, so only Ultra Quality and Super Quality will be available. More profiles will be available when you select a bigger nozzle size.
    • Thanks 1
    That was exactly the issue; at some point I selected "Generic PLA 0.2 Nozzle" for the material.
    Thank you!
        • 4 replies
