thanks. I didn't know there was a reply till today. I thought there would be a notification for replies.
GregValiant 1,112
I think you have to turn it on in your settings or nitification settings. I was going to remind you but I didn't want to poke my nose in.
Edited by GregValiant-
2
GregValiant 1,112
Throughout my 72 years I have found that you can never go wrong with a red clown nose. I can see how it might not work for Dumbledore, but I've always considered them to be "A nose for all occasions".
Maybe you could wear one and say things like "If I ever catch the student who is responsible for this....".
I found this "Nose Box" on Thingiverse. It has a wide variety of noses. By dropping it into the build plate you can get the side you want to print. Scaling it should get the one you choose to the right size. Here I've added support blockers configured as cutting mesh with 0 wall, 0 top/bottom layers, and 0 infill to get rid of a couple and also the ridge that would have wanted to print.
No bottom layers, set the infill density to 20% and the Infill Flow to 85 or 90% so it breaks out easy.
Maybe you could print it in red? That would make me proud.
Oh...make sure you get the Z seam right or you will look silly.
