I'm sorry I don't know blender but are there options for the units you are drawing in? If you are drawing and export the file as inches then it will come into Cura and be autoscaled. Cura is guessing. So you need to double check the units in Blender and the Blender export utility (if it has options).
Once the model is in Cura, select it and use the Scale tool and adjust the Z to 20mm. With the "Uniform Scaling" box checked you should get the X and Y for free. and they should be really close to 50mm. After you do that check the % boxes and they may give a clue as to what scale Blender exported the model.
A lot of Cad modeling apps don't care about units. They only know that two lines are "1.00000000" apart. It could be lightyears or nanometers for all the Cad app cares.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
GregValiant 1,142
