Hey @flyntm,
Thanks for your question 👍
I must admit that I thought the same when I saw the material station for the first time but the software doesn't support printing more than 2 colors. It was not created to enable printing with more than 2 colors, just to make sure that the printer keeps printing if your material runs out.
But in the office we have printjobs like this by triggering an end of filament.
I want to emphasize that this is not a supported workflow and it would require some practice, but...
It's relatively easy to trick the printer in the following three ways
A. You can add a pause at height in the Cura Post Processing Script
B. You can trigger a faulty end of filament by grabbing your filament before it enters the material station and giving it a jerk
C. You can load a new filament that has a different color but also select it to be generic PLA like the material that "has run out"
So if you really want to, I think it's possible to do it, but don't tell anyone I told you 🤭
Dadkitess 21
Well, IIRC, no, it's not possible. Do not own it though, just remember what the commercial told me and it surprised me a LOT as it would clearly be required to be worth the price.
