Dear all,
I was triggered by the fact that you get the 'Unknown build plate' message.
I get this message on a S5 and figured out that I get this message only when using Cura 5.2.1, but not when using Cura 5.1.0.
I tried several settings and designs but the same behavior.
Something in Cura 5.2.1 causing this problem?
gr5 2,243
Thanks for explaining that the nozzle doesn't touch the buildplate in failure mode. 99% of people don't mention this and it's crucial information as there are 2 other failure modes.
I believe in the maintenance menu there is a way to test the sensor. It should return a value. Values at 8 and below are good. The larger the value the more noise or something is detected? I'm not sure exactly. Values around 15 I think cause intermittent failures.
Anyway run that test a few times to get a baseline and assuming it's well over 8 try some things and try to get that to a lower value. Get a baseline with the 3 fans off and again with the front fan on (actually maybe you are forced to have the front on during the test? not sure).
Check the two wires to the sensor. When you open the front door on the print head the sensor swings down - it's in the base of the print head. It's basically a flat metal plate and the capacitance is determined by the distance from that plate to the metal plate under the glass bed.
Tug very gently on the two wires to see if one pulls free because it's not connected at all or was barely connected. That was my issue on my printer when it was failing active leveling.
Next fan cable. Try rerouting the front fan wires. Or unplugging the fan. Sometimes the solution is to replace the front fan. If it works fine with the fan off but fails with the fan on then you need to either route the fan cables farther from the sensor cables or you need to get a new fan.
I believe the side fans don't matter because I think they are off during leveling.
gr5 2,243
By the way if you have older firmware it doesn't report the number on the screen but you can get it from the log file if you open the file containing "boot0.log" in the filename and search for "noise std". When I did the test I got a noise value of 2.2. A friend of mine got a 3. Again, anything < 8 is pass.
